Introdução
This guide will lead you through the steps of removing the USB Add-on Card attached on the motherboard.
O que você precisa
Locate and remove the 5 screws that secure the panel over the RAM and CPU cover on the upper right hand side. These can be found in the center towards the corner opposite the battery compartment.
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Under the panel, remove the two screws that connect the keyboard to the laptop.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
You do not need to remove the whole cover, in order to replace the keyboard.
The description for this job is right.
The switch plate cover just pops off.
Screws revealed, secure the keyboard.
Unclip the ribbon cable.
Job done
Richard -
Remove the nine screws from the back edges of the laptop.
Um comentário
اello
I have a problem at all entrances usb not working
When Enter the device show me unknown device
The show I've been arrested for this device that caused the problem (code 43)
I did not understand the problem, despite all attempts
Where do I start testing now, sir
I hope to answer in the near future sir
Thank you
