Ir para o conteúdo principal
Acer Aspire 5100 Track Pad Replacement
O que você precisa
  1. Acer Aspire 5100 Track Pad Replacement, Keyboard: passo 1, imagem 1 %32 Acer Aspire 5100 Track Pad Replacement, Keyboard: passo 1, imagem 2 %32
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Track Pad Replacement: passo 2, imagem 1 %32 Acer Aspire 5100 Track Pad Replacement: passo 2, imagem 2 %32 Acer Aspire 5100 Track Pad Replacement: passo 2, imagem 3 %32
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Track Pad Replacement: passo 3, imagem 1 %32
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 Track Pad Replacement, Track Pad: passo 4, imagem 1 %32
    • Remove the nine screws from the back edges of the laptop.
  5. Acer Aspire 5100 Track Pad Replacement: passo 5, imagem 1 %32 Acer Aspire 5100 Track Pad Replacement: passo 5, imagem 2 %32 Acer Aspire 5100 Track Pad Replacement: passo 5, imagem 3 %32
    • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
    • Use the spudger to pry open the sides of this cover.
    • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
  6. Acer Aspire 5100 Track Pad Replacement: passo 6, imagem 1 %32 Acer Aspire 5100 Track Pad Replacement: passo 6, imagem 2 %32
    • Slightly lift up the cover to see the ribbon connection.
    • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
    • Lift up the cover from the laptop.
  7. Acer Aspire 5100 Track Pad Replacement: passo 7, imagem 1 %32
    • On the cover that was removed, flip it around and locate where the back of the track pad is.
    • Remove the three screws located at the corners.
    • Lift up the bracket that you just unscrewed and remove track pad.
Conclusão
Brad Rollinson
Membro desde: 09/29/10
1.113 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 14-39, Forte Fall 2010 Membro de Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
Membros da 5
Autoria de 10 guias
3 comentários
You left out about 10 screws & assemblies that have to ALSO be removed to release the cover that surrounds the keyboard and track pad.
Jack Hickey - Responder
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should remove the parts I mentioned before attempting to complete steps 5 to 7.
Nelson Mata - Responder
The Fan must also be removed before removing the touchpad/upper cover.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 9,381
