Ir para o conteúdo principal
Acer Aspire 5100 RAM Replacement
O que você precisa
  1. Acer Aspire 5100 RAM Replacement, RAM: passo 1, imagem 1 %32 Acer Aspire 5100 RAM Replacement, RAM: passo 1, imagem 2 %32
    • Remove the screws on the large panel.
    • Lift up the panel.
  2. Acer Aspire 5100 RAM Replacement: passo 2, imagem 1 %32 Acer Aspire 5100 RAM Replacement: passo 2, imagem 2 %32 Acer Aspire 5100 RAM Replacement: passo 2, imagem 3 %32
    • The RAM slots are located in the corner opposite to the cooling fan.
    • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
    • Slide in the RAM at a 45 degree angle.
    • Press down on the RAM until it snaps into place.
    • A good amount of pressure is needed to snap it in place.
    • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
Conclusão
7 outras pessoas executaram este guia.
Brad Rollinson
Membro desde: 09/29/10
1.113 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 14-39, Forte Fall 2010 Membro de Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
Membros da 5
Autoria de 10 guias
Um comentário
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 16,300
