Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
Upgrade or replace RAM.
  1. Remove the screws on the large panel. Lift up the panel.
    • Remove the screws on the large panel.
    • Lift up the panel.
  2. The RAM slots are located in the corner opposite to the cooling fan. To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out. Slide in the RAM at a 45 degree angle.
    • The RAM slots are located in the corner opposite to the cooling fan.
    • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
    • Slide in the RAM at a 45 degree angle.
    • Press down on the RAM until it snaps into place.
    • A good amount of pressure is needed to snap it in place.
    • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
Conclusão
7 outras pessoas concluíram este guia.
Brad Rollinson
Membro desde: 29-09-2010
1.101 Reputation
7 Guias de autoria
Equipe
Cal Poly, Team 14-39, Forte Fall 2010 Membro de Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Membros
9 Guias de autoria
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Responder
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 15,407
