Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replace motherboard in an Acer Aspire 5100.
O que você precisa
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Locate and remove the screws on the motherboard.
There is normally only one remaining screw holding the board. Bottom right (sometimes under tape).
All the other screw holes except screws holding the base cover on and are kept empty.
8 outras pessoas executaram este guia.
6 comentários
Thank you. I followed the guide as closely as possible. I am installing Windows 76 Ultimate on it again.
Thank you!
a lot of stuff missing in terms of unscrewing certain screws to get the cover off. I got stuck at step 10 because the cover was still attached by various screws.
Maybe I have a different model, but it is for sure an Acer Aspire 5100.
I also broke a lot of connection where screws thread in to, hopefully it goes back together rigidly enough.
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should complete steps 12 to 16 and remove the 10x screws before attempting to complete steps 9 to 11.
