Ir para o conteúdo principal
Acer Aspire 5100 CPU Replacement
O que você precisa
  1. Acer Aspire 5100 CPU Replacement, Fan: passo 1, imagem 1 %32
    • Flip the laptop upside-down.
    • Remove the battery as a safety precaution.
    • Remove the four screws attached to the large panel.
  2. Acer Aspire 5100 CPU Replacement: passo 2, imagem 1 %32
    • Lift and remove the panel.
  3. Acer Aspire 5100 CPU Replacement: passo 3, imagem 1 %32
    • Remove the two screws attached to the fan.
  4. Acer Aspire 5100 CPU Replacement: passo 4, imagem 1 %32 Acer Aspire 5100 CPU Replacement: passo 4, imagem 2 %32
    • Lift the fan and detach the cable that connects the fan to the motherboard.
    • The fan can break easily. Be careful when removing.
    • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
  5. Acer Aspire 5100 CPU Replacement, Keyboard: passo 5, imagem 1 %32 Acer Aspire 5100 CPU Replacement, Keyboard: passo 5, imagem 2 %32
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  6. Acer Aspire 5100 CPU Replacement: passo 6, imagem 1 %32 Acer Aspire 5100 CPU Replacement: passo 6, imagem 2 %32 Acer Aspire 5100 CPU Replacement: passo 6, imagem 3 %32
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  7. Acer Aspire 5100 CPU Replacement: passo 7, imagem 1 %32
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  8. Acer Aspire 5100 CPU Replacement, Track Pad: passo 8, imagem 1 %32
    • Remove the nine screws from the back edges of the laptop.
  9. Acer Aspire 5100 CPU Replacement: passo 9, imagem 1 %32 Acer Aspire 5100 CPU Replacement: passo 9, imagem 2 %32 Acer Aspire 5100 CPU Replacement: passo 9, imagem 3 %32
    • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
    • Use the spudger to pry open the sides of this cover.
    • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
  10. Acer Aspire 5100 CPU Replacement: passo 10, imagem 1 %32 Acer Aspire 5100 CPU Replacement: passo 10, imagem 2 %32
    • Slightly lift up the cover to see the ribbon connection.
    • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
    • Lift up the cover from the laptop.
  11. Acer Aspire 5100 CPU Replacement: passo 11, imagem 1 %32
    • On the cover that was removed, flip it around and locate where the back of the track pad is.
    • Remove the three screws located at the corners.
    • Lift up the bracket that you just unscrewed and remove track pad.
  12. Acer Aspire 5100 CPU Replacement, LCD Monitor: passo 12, imagem 1 %32
    • Remove the two screws from each corner beneath the LCD screen.
  13. Acer Aspire 5100 CPU Replacement: passo 13, imagem 1 %32 Acer Aspire 5100 CPU Replacement: passo 13, imagem 2 %32
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  14. Acer Aspire 5100 CPU Replacement: passo 14, imagem 1 %32 Acer Aspire 5100 CPU Replacement: passo 14, imagem 2 %32
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  15. Acer Aspire 5100 CPU Replacement: passo 15, imagem 1 %32
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  16. Acer Aspire 5100 CPU Replacement: passo 16, imagem 1 %32
    • Lift up the monitor to detach it.
  17. Acer Aspire 5100 CPU Replacement, Motherboard: passo 17, imagem 1 %32
    • Remove the 15 screws from the motherboard.
    • There is normally only one remaining screw attached to the motherboard on the bottom right beneath the tape.
    • All the other screw holes (except screws holding the base cover on) are kept empty.
  18. Acer Aspire 5100 CPU Replacement: passo 18, imagem 1 %32
    • Locate the heat sink, which is the copper "L" shaped component, and unscrew the four screws that connect it to the motherboard.
  19. Acer Aspire 5100 CPU Replacement: passo 19, imagem 1 %32
    • Push out the back of the casing by the VGA connector to remove the motherboard.
  20. Acer Aspire 5100 CPU Replacement: passo 20, imagem 1 %32 Acer Aspire 5100 CPU Replacement: passo 20, imagem 2 %32
    • Lift up and remove the motherboard from the laptop casing.
    • Remove the USB add-on card to use it with the new motherboard.
    • To remove, grab on the sides and lift upward.
  21. Acer Aspire 5100 CPU Replacement, CPU: passo 21, imagem 1 %32
    • Loosen the screw to the CPU by rotating counter clockwise. The use of a flat head screwdriver will be needed.
  22. Acer Aspire 5100 CPU Replacement: passo 22, imagem 1 %32
    • Carefully pull up on the CPU from the circuit board without twisting or rotating as connections may become bent.
    • You now have the CPU, you may inspect it to check for any damages or replacement as necessary
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
Hello sir
Can I switch to cpu amd advanced chip intel or I can not do so
Thank you
Message me on email
rabaharif1993@gmail.com
rabah arif - Responder
It is not worth the improvement.
Imi13 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 4,542
