Introdução
This guide will show you how to upgrade the RAM in the Acer Aspire 5 A515-56-347N. There is one user-replaceable RAM slot on the motherboard. From the factory, this RAM slot is empty.
Electrostatic discharge (ESD) can irreparably damage the components of your computer. While following this guide, avoid wearing static-prone clothing such as wool or flannel, or working on surfaces such as carpet. Optionally, you may use an ESD bracelet and/or mat to remain grounded throughout the repair process and minimize the risk of ESD damage.
For additional information, you may consult this device's safety guide and user manual (see attachments), or the manufacturer's support page.
O que você precisa
Turn the laptop off, and disconnect the power cable.
Flip the laptop upside down.
Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
Once loosened, pull back on the tape to remove it from the connector.
Use a plastic spudger to pull the battery connector away from the motherboard.
Holding the RAM chip by its sides, line it up with the notches in the RAM slot.
Gently push the RAM chip down until you hear the metal tabs on the sides click.
