Introdução
If you are running out of storage space in your Acer Aspire 5 A515-56-347N, this guide will show you how to remove the laptop's factory-installed PCIe SSD in order to replace it or upgrade it with a higher-capacity unit.
Electrostatic discharge (ESD) can irreparably damage the components of your computer. While following this guide, avoid wearing static-prone clothing such as wool or flannel, or working on surfaces such as carpet. Optionally, you may use an ESD bracelet and/or mat to remain grounded throughout the repair process and minimize the risk of ESD damage.
For additional information, you may consult this device's safety guide and user manual (see attachments), or the manufacturer's support page.
O que você precisa
Turn the laptop off, and disconnect the power cable.
Flip the laptop upside down.
Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
Once loosened, pull back on the tape to remove it from the connector.
Use a plastic spudger to pull the battery connector away from the motherboard.
Using a Phillips #0 screwdriver, remove the small 4.5 mm screw securing the SSD to the laptop chassis.
The SSD is now loose and can be removed.
