Ir para o conteúdo principal
Acer Aspire 4810TZ-4120 Screen Replacement
O que você precisa
  1. Acer Aspire 4810TZ-4120 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Unlock the battery by pushing and holding the lock button.
  2. Acer Aspire 4810TZ-4120 Screen Replacement: passo 2, imagem 1 %32 Acer Aspire 4810TZ-4120 Screen Replacement: passo 2, imagem 2 %32
    • While holding the lock button, pull out the battery
    • The battery is now ready to be replaced with a new one
  3. Acer Aspire 4810TZ-4120 Screen Replacement, Screen: passo 3, imagem 1 %32 Acer Aspire 4810TZ-4120 Screen Replacement, Screen: passo 3, imagem 2 %32
    • Locate and remove the four (4) pads using Angled Tweezers
  4. Acer Aspire 4810TZ-4120 Screen Replacement: passo 4, imagem 1 %32 Acer Aspire 4810TZ-4120 Screen Replacement: passo 4, imagem 2 %32
    • Remove the four screws that were under the pads
  5. Acer Aspire 4810TZ-4120 Screen Replacement: passo 5, imagem 1 %32 Acer Aspire 4810TZ-4120 Screen Replacement: passo 5, imagem 2 %32 Acer Aspire 4810TZ-4120 Screen Replacement: passo 5, imagem 3 %32
    • Carefully pull the bevel (frame) off of the screen
  6. Acer Aspire 4810TZ-4120 Screen Replacement: passo 6, imagem 1 %32 Acer Aspire 4810TZ-4120 Screen Replacement: passo 6, imagem 2 %32 Acer Aspire 4810TZ-4120 Screen Replacement: passo 6, imagem 3 %32
    • Locate the four screws that are holding the screen in place
    • Remove the screws
  7. Acer Aspire 4810TZ-4120 Screen Replacement: passo 7, imagem 1 %32 Acer Aspire 4810TZ-4120 Screen Replacement: passo 7, imagem 2 %32
    • Pull the screen out gently
    • Lay the screen down on the keyboard
  8. Acer Aspire 4810TZ-4120 Screen Replacement: passo 8, imagem 1 %32 Acer Aspire 4810TZ-4120 Screen Replacement: passo 8, imagem 2 %32
    • Locate the connector between the screen and the computer
    • Remove any tape
  9. Acer Aspire 4810TZ-4120 Screen Replacement: passo 9, imagem 1 %32
    • Gently pull the connector off of the screen
    • The screen can now be replaced with a new one
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 475
