Ir para o conteúdo principal
Acer Aspire 4810TZ-4120 Keyboard Replacement
O que você precisa
  1. Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Locate the five (5) tabs at the top of the keyboard that are holding it in place
    • The 2nd and 3rd pictures are close ups of the tabs
  2. Acer Aspire 4810TZ-4120 Keyboard Replacement: passo 2, imagem 1 %32 Acer Aspire 4810TZ-4120 Keyboard Replacement: passo 2, imagem 2 %32
    • The first picture shows the notches in the keyboard that the tabs to into to hold it in place. You cannot see these until the keyboard is removed
    • Insert the flat part of the Spudger tool into one of the holes in front of the tab
    • Push the tab back so it is no longer holding the keyboard.
    • Repeat this step for all of the tabs
  3. Acer Aspire 4810TZ-4120 Keyboard Replacement: passo 3, imagem 1 %32 Acer Aspire 4810TZ-4120 Keyboard Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lay the keyboard upside down
    • Remove any tape that is on the connector with tweezers
    • Gently remove the connector that is on the ribbon cable from the back of the keyboard
    • Your keyboard is now ready to be replaced with a new one
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 520
