Ir para o conteúdo principal
Acer Aspire 4743-6481 Ram Card Replacement
O que você precisa
  1. Acer Aspire 4743-6481 Ram Card Replacement, Battery: passo 1, imagem 1 %32
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Ram Card Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Ram Card Replacement: passo 3, imagem 1 %32
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Ram Card Replacement, RAM Card: passo 4, imagem 1 %32
    • Remove three 7.0 mm screws with a Phillips head screwdriver from the back panel to gain access to the RAM cards.
  5. Acer Aspire 4743-6481 Ram Card Replacement: passo 5, imagem 1 %32
    • Place the device with the battery side facing up, as shown on the picture.
    • After removing the back panel, you will see the RAM cards located to the right.
  6. Acer Aspire 4743-6481 Ram Card Replacement: passo 6, imagem 1 %32
    • You should notice a silver tab on each side of the RAM card. Push each tab away at the same time to detach the card.
  7. Acer Aspire 4743-6481 Ram Card Replacement: passo 7, imagem 1 %32
    • If done successfully, the RAM should pop out and you can lift it out with no effort.
Conclusão
AL-Moatasem
Membro desde: 02/22/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S5-G1, Lacy Spring 2017 Membro de USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 727
