Ir para o conteúdo principal
Acer Aspire 4743-6481 Keyboard Replacement
O que você precisa
  1. Acer Aspire 4743-6481 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Keyboard Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Keyboard Replacement: passo 3, imagem 1 %32
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Remove the two 6.0 mm screws that secure the keyboard using a Phillips head screwdriver.
    • They can be easily identified by looking for the screws with the keyboard icon next to them.
  5. Acer Aspire 4743-6481 Keyboard Replacement: passo 5, imagem 1 %32 Acer Aspire 4743-6481 Keyboard Replacement: passo 5, imagem 2 %32
    • Turn the laptop over and open it.
    • Use flat edged tools to gently separate the keyboard from the laptop. It should snap off with a small amount of force.
    • Be sure to push the small tabs along the top of the keyboard, while lifting to successfully free the keyboard.
  6. Acer Aspire 4743-6481 Keyboard Replacement: passo 6, imagem 1 %32
    • Gently lift away the keyboard, making sure not to damage the data cable or the connector.
    • The connection is located beneath the bottom center of the keyboard.
  7. Acer Aspire 4743-6481 Keyboard Replacement: passo 7, imagem 1 %32
    • Remove piece of tape that covers the connection between the data cable and the connector.
  8. Acer Aspire 4743-6481 Keyboard Replacement: passo 8, imagem 1 %32
    • Detach the data cable by flipping up the small black latch on the connector.
    • Once the latch is lifted, the keyboard should be completely free.
Conclusão
3 outras pessoas executaram este guia.
David Veres
Membro desde: 02/22/17
140 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S5-G1, Lacy Spring 2017 Membro de USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Duração total: 1,401
