Ir para o conteúdo principal
Acer Aspire 4741G-332G32Mn Motherboard Replacement
O que você precisa
  1. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the lock latch to unlock battery.
  2. Acer Aspire 4741G-332G32Mn Motherboard Replacement: passo 2, imagem 1 %32
    • Slide the middle latch and remove the battery.
  3. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: passo 3, imagem 1 %32 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: passo 3, imagem 2 %32 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: passo 3, imagem 3 %32
    • Pry off the keyboard using the opening tool.
    • Remove the two screws that are connected to the motherboard using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Motherboard Replacement: passo 4, imagem 1 %32
    • Remove all 12 screws from the backplate using a Phillips #0 screwdriver.
  5. Acer Aspire 4741G-332G32Mn Motherboard Replacement: passo 5, imagem 1 %32
    • Using the prying tool to remove the bottom of the laptop.
  6. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: passo 6, imagem 1 %32 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: passo 6, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the eight screws that hold the motherboard to the frame of the laptop.
    • Disconnect the USB port from the motherboard.
  7. Acer Aspire 4741G-332G32Mn Motherboard Replacement: passo 7, imagem 1 %32 Acer Aspire 4741G-332G32Mn Motherboard Replacement: passo 7, imagem 2 %32
    • Unscrew the 6 screws that hold the fan to the motherboard using the same screwdriver.
  8. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Remove the motherboard from the device.
Conclusão
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 1,214
