Ir para o conteúdo principal
Acer Aspire 4520-5464 WiFi Wireless Card Replacement
O que você precisa
  1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 2, imagem 1 %32 Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 2, imagem 2 %32
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 3, imagem 1 %32
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: passo 4, imagem 1 %32 Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two 0.5mm screws from the smallest panel on the back of the computer.
    • Set the screws aside.
    • Lift up the panel using the indent located on the left side of the panel.
  5. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 5, imagem 1 %32
    • Remove both the black and white wires by pinching the brass connectors and pulling up.
  6. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 6, imagem 1 %32
    • Remove the two 0.5mm Phillips #1 black screws located on the WiFi card.
  7. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: passo 7, imagem 1 %32
    • Lift the WiFi card on the left side to remove it.
Conclusão
To reassemble your device, follow these instructions in reverse order with a new WiFi wireless card.
Byeloth Hermanson
Membro desde: 09/21/17
285 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,016
