Ir para o conteúdo principal
Acer Aspire 4520-5464 Hard Drive Replacement
O que você precisa
  1. Acer Aspire 4520-5464 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Hard Drive Replacement: passo 2, imagem 1 %32 Acer Aspire 4520-5464 Hard Drive Replacement: passo 2, imagem 2 %32
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Hard Drive Replacement: passo 3, imagem 1 %32
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
    • Remove the seven 2mm Phillips #1 screws from the largest panel on the back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Hard Drive Replacement: passo 5, imagem 1 %32 Acer Aspire 4520-5464 Hard Drive Replacement: passo 5, imagem 2 %32 Acer Aspire 4520-5464 Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove the two 0.5mm Phillips #1 black screws left of the Hard Drive.
    • Remove the two 0.5mm Phillips #1 silver on top of the Hard Drive.
    • Lift up and remove the hard drive bracket by the plastic tab on top of the hard drive.
  6. Acer Aspire 4520-5464 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the hard drive from the device.
Conclusão
Hunter Gilcrease
Membro desde: 09/21/17
367 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 811
