Ir para o conteúdo principal
Acer Aspire 4520-5464 Graphics Card Replacement
O que você precisa
  1. Acer Aspire 4520-5464 Graphics Card Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Graphics Card Replacement: passo 2, imagem 1 %32 Acer Aspire 4520-5464 Graphics Card Replacement: passo 2, imagem 2 %32
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Graphics Card Replacement: passo 3, imagem 1 %32
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: passo 4, imagem 1 %32 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: passo 4, imagem 2 %32 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: passo 4, imagem 3 %32
    • Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
    • Set the screws aside.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Graphics Card Replacement: passo 5, imagem 1 %32
    • Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
  6. Acer Aspire 4520-5464 Graphics Card Replacement: passo 6, imagem 1 %32
    • Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
  7. Acer Aspire 4520-5464 Graphics Card Replacement: passo 7, imagem 1 %32 Acer Aspire 4520-5464 Graphics Card Replacement: passo 7, imagem 2 %32
    • Lift up the heat sink line and remove the graphics card.
Conclusão
Hunter Gilcrease
Membro desde: 09/21/17
367 Reputação
Autoria de 3 guias
Equipe
Um comentário
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
Fernando Rodrigues - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 2,381
