Introdução
This guide will show you how to replace or upgrade the Graphics Card of an Acer Aspire 4520-5464 laptop. The graphics card allows graphics to be displayed on the screen of the laptop.
O que você precisa
Shut down the computer and disconnect all external devices and cables.
Flip the computer over.
Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
Lift up the panel from the indent located on the right side.
Um comentário
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
