Ir para o conteúdo principal
Acer Aspire 4520-5464 CD/DVD Drive Replacement
O que você precisa
  1. Acer Aspire 4520-5464 CD/DVD Drive Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 CD/DVD Drive Replacement: passo 2, imagem 1 %32 Acer Aspire 4520-5464 CD/DVD Drive Replacement: passo 2, imagem 2 %32
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 CD/DVD Drive Replacement: passo 3, imagem 1 %32
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: passo 4, imagem 1 %32 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: passo 4, imagem 2 %32 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: passo 4, imagem 3 %32
    • Remove 7 of the 2mm Phillips #1 screw from the largest panel on back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 CD/DVD Drive Replacement: passo 5, imagem 1 %32
    • Remove the .5mm Phillips #1 black screw located on the left side of the panel opening.
  6. Acer Aspire 4520-5464 CD/DVD Drive Replacement: passo 6, imagem 1 %32 Acer Aspire 4520-5464 CD/DVD Drive Replacement: passo 6, imagem 2 %32
    • Using the screwdriver, push the CD drive out of the laptop through the panel exposure.
Conclusão
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 408
