Introdução
This guide will show you how to replace your old battery with a new one.
The battery is the main source of power for your computer. Without a battery, the
computer cannot be powered on unless it is plugged into a wall socket.
Replacing the battery is an easy task with little risk of damaging critical components
inside your computer.
Shut down the computer and disconnect all external devices and cables.
Flip the computer over.
To reassemble your device, follow these instructions in reverse order using a new battery.
2 outras pessoas concluíram este guia.
