Ir para o conteúdo principal
Acer Aspire 3003WLCi Hard Drive Replacement
O que você precisa
  1. Acer Aspire 3003WLCi Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
  2. Acer Aspire 3003WLCi Hard Drive Replacement: passo 2, imagem 1 %32 Acer Aspire 3003WLCi Hard Drive Replacement: passo 2, imagem 2 %32 Acer Aspire 3003WLCi Hard Drive Replacement: passo 2, imagem 3 %32
    • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
    • Shift the bottom switch into an upward position in order to unlock the battery.
    • To unlock the upper switch, forcefully push the switch up and hold it in this position.
  3. Acer Aspire 3003WLCi Hard Drive Replacement: passo 3, imagem 1 %32 Acer Aspire 3003WLCi Hard Drive Replacement: passo 3, imagem 2 %32
    • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
    • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
    • You have to maintain pulling the upper switch upwards, or the battery will not come out.
  4. Acer Aspire 3003WLCi Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Locate the hard drive access panel in the upper right corner of the laptop.
  5. Acer Aspire 3003WLCi Hard Drive Replacement: passo 5, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the two 5mm captive screws attached to the access panel.
    • The screws will not come out all the way. Once they are loose enough you should be able to open the panel.
  6. Acer Aspire 3003WLCi Hard Drive Replacement: passo 6, imagem 1 %32
    • Lift and remove the panel to access the hard drive.
    • This panel can be difficult to remove. If you have trouble, use a spudger to pry the cover up.
  7. Acer Aspire 3003WLCi Hard Drive Replacement: passo 7, imagem 1 %32 Acer Aspire 3003WLCi Hard Drive Replacement: passo 7, imagem 2 %32
    • The hard drive is connected to the computer; simply pull it back from the connector and take it out of the laptop casing.
Conclusão
Tristin Viale
Membro desde: 03/25/19
675 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 399
