Ir para o conteúdo principal
Acer Aspire 3000 Wireless Card Replacement
O que você precisa
  1. Acer Aspire 3000 Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Wireless Card Replacement: passo 2, imagem 1 %32 Acer Aspire 3000 Wireless Card Replacement: passo 2, imagem 2 %32
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Wireless Card Replacement: passo 3, imagem 1 %32 Acer Aspire 3000 Wireless Card Replacement: passo 3, imagem 2 %32
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Wireless Card Replacement, Wireless Card: passo 4, imagem 1 %32
    • Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
  5. Acer Aspire 3000 Wireless Card Replacement: passo 5, imagem 1 %32
    • Pop the three side tabs out of the back case.
  6. Acer Aspire 3000 Wireless Card Replacement: passo 6, imagem 1 %32
    • Remove the panel that covers the graphics card.
  7. Acer Aspire 3000 Wireless Card Replacement: passo 7, imagem 1 %32
    • Remove the black and white cables attached to the graphics card.
    • Be careful to lift vertically as to not mess up either part of the connectors.
  8. Acer Aspire 3000 Wireless Card Replacement: passo 8, imagem 1 %32
    • Push the white flanges on either side of the graphics card out.
    • The card should lift on its own slightly out of the case.
  9. Acer Aspire 3000 Wireless Card Replacement: passo 9, imagem 1 %32
    • Remove the card by lifting up and away from the edge that has all of the contacts on it.
Conclusão
Lykia Harper
Membro desde: 10/29/16
258 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 4-2, Williams Fall 2016 Membro de Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 951
