Introdução
This step-by- step process demonstrates how to replace an old keyboard on your Acer Aspire 3000. It is important to follow the steps carefully in order to prevent damage to the connectors or laptop itself upon removal of the keyboard. Damage to the connectors may cause a bad connection with the new replacement keyboard. Use caution to always remove the battery whenever you are repairing parts of your device.
O que você precisa
Begin with the device face down.
Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
Lift the laptop to be on its edge, with the bottom of the screen in the air.
Uma outra pessoa concluiu este guia.
