Ir para o conteúdo principal
Acer Aspire 3000 Hard Drive Replacement
O que você precisa
  1. Acer Aspire 3000 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Hard Drive Replacement: passo 2, imagem 1 %32 Acer Aspire 3000 Hard Drive Replacement: passo 2, imagem 2 %32
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Hard Drive Replacement: passo 3, imagem 1 %32 Acer Aspire 3000 Hard Drive Replacement: passo 3, imagem 2 %32
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Unscrew the two 4.6 mm Phillips #1 screws on the left side of the hard drive panel in the lower right corner on the back of the laptop using the phillips head j1 bit.
  5. Acer Aspire 3000 Hard Drive Replacement: passo 5, imagem 1 %32 Acer Aspire 3000 Hard Drive Replacement: passo 5, imagem 2 %32 Acer Aspire 3000 Hard Drive Replacement: passo 5, imagem 3 %32
    • Insert the plastic opening tool under left side of the hard drive cover and gently pry the cover open.
    • Pull the cover up and out to release the tabs on the right side of the cover and remove from the device.
Conclusão
4 outras pessoas executaram este guia.
Courtney Lyons
Membro desde: 10/30/16
199 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 4-2, Williams Fall 2016 Membro de Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 2,060
