Ir para o conteúdo principal
Acer Aspire 3 A315-21-92FX Speakers Replacement
O que você precisa
  1. Acer Aspire 3 A315-21-92FX Speakers Replacement, RAM: passo 1, imagem 1 %32
    • Flip the Acer Aspire 3 A315-21-92FX over so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 2, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 2, imagem 2 %32
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 3, imagem 1 %32
    • Use the iFixit opening tool to remove the small cover.
  4. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 4, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 4, imagem 2 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 4, imagem 3 %32
    • Press the tabs on each side of the RAM outwards, and the memory module will pop up at an angle.
  5. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 5, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 5, imagem 2 %32
    • Pull the RAM slowly out of the Acer Aspire 3 A315-21-92FX.
  6. Acer Aspire 3 A315-21-92FX Speakers Replacement, Hard Drive: passo 6, imagem 1 %32
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  7. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 7, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 7, imagem 2 %32
  8. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 8, imagem 1 %32
    • Use the iFixit opening tool to remove the cover of the hard disk.
  9. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 9, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 9, imagem 2 %32
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
  10. Acer Aspire 3 A315-21-92FX Speakers Replacement, Battery: passo 10, imagem 1 %32
    • Remove fourteen 2.5mm Phillips #0 screws from the back of the laptop.
    • There may be two additional screws under the hard drive cover that must be removed before attempting to remove the back cover.
  11. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 11, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 11, imagem 2 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 11, imagem 3 %32
    • Use the iFixit opening tool to remove the back cover.
  12. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 12, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 12, imagem 2 %32
    • Pull out the plug connecting the battery to the motherboard.
  13. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 13, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 13, imagem 2 %32
    • Pull the battery out of the groove.
  14. Acer Aspire 3 A315-21-92FX Speakers Replacement, Speakers: passo 14, imagem 1 %32
    • Remove the speaker located in the right hand of the device first using the iFixit Opening Tool.
    • Place the edge of the iFixit Opening Tool under the speaker and pull it upward.
  15. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 15, imagem 1 %32
    • Remove the speaker from the left side of the computer using the iFixit Opening Tool.
  16. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 16, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 16, imagem 2 %32
    • The cable that is connecting the speakers to the motherboard is placed under these plastic cables that are glued to the computer.
    • Remove these glued cables using the iFixit Opening Tool.
  17. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 17, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 17, imagem 2 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 17, imagem 3 %32
    • Detach the speaker connector from the motherboard with your fingers or the iFixit Opening Tool.
  18. Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 18, imagem 1 %32 Acer Aspire 3 A315-21-92FX Speakers Replacement: passo 18, imagem 2 %32
    • Remove the speakers with your hands.
Conclusão
3 outras pessoas executaram este guia.
gghhh
Membro desde: 01/14/20
329 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 1,476
