Ir para o conteúdo principal
Acer Aspire 3 A315-21-92FX Hard Drive Replacement
O que você precisa
  1. Acer Aspire 3 A315-21-92FX Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 2, imagem 1 %32 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 3, imagem 1 %32
    • Use the iFixit opening tool to remove the cover of the hard disk.
  4. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 4, imagem 1 %32 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: passo 4, imagem 2 %32
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
Conclusão
4 outras pessoas executaram este guia.
ShengKun Lu
Membro desde: 01/14/20
757 Reputação
Autoria de 3 guias
Equipe
2 comentários
My acer aspire 3 A315-32 says no bootable device I had tried to boot Linux from USB but I partioned the hard drive so I fixed it by changing the format and deleting everything and installed windows on a different pc but it’s still not booting even on boot options it’s not showing
Zeek tuyishime - Responder
These connecting cable is missing, where to buy these cable. Pls tell the cable name
jayesh v v - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 78
Ao todo: 6,856
