Ir para o conteúdo principal
Acer AL1916 Outer Case Replacement
O que você precisa
  1. Acer AL1916 Outer Case Replacement, Stand: passo 1, imagem 1 %32
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Outer Case Replacement: passo 2, imagem 1 %32 Acer AL1916 Outer Case Replacement: passo 2, imagem 2 %32
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Outer Case Replacement: passo 3, imagem 1 %32 Acer AL1916 Outer Case Replacement: passo 3, imagem 2 %32
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Acer AL1916 Outer Case Replacement, Outer Case: passo 4, imagem 1 %32 Acer AL1916 Outer Case Replacement, Outer Case: passo 4, imagem 2 %32
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 Outer Case Replacement: passo 5, imagem 1 %32 Acer AL1916 Outer Case Replacement: passo 5, imagem 2 %32 Acer AL1916 Outer Case Replacement: passo 5, imagem 3 %32
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 Outer Case Replacement: passo 6, imagem 1 %32 Acer AL1916 Outer Case Replacement: passo 6, imagem 2 %32
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
Conclusão
Keith
Membro desde: 10/06/11
351 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 20-26, Maness Fall 2011 Membro de Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,255
