Ir para o conteúdo principal
Acer AL1714 Power Button Circuit Board Flat Flex Cables Replacement
O que você precisa
  1. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: passo 1, imagem 1 %32 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: passo 1, imagem 2 %32
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 2, imagem 1 %32 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 2, imagem 2 %32 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 2, imagem 3 %32
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 3, imagem 1 %32 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 3, imagem 2 %32 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 3, imagem 3 %32
    • Remove the Power Button Circuit board Flat Flex Cable from the Power Supply board under the metal cage.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: passo 4, imagem 1 %32
    • Remove the Flat Flex Cables from the Power Button Circuit Board.
Conclusão
Christopher Kelly
Membro desde: 09/25/14
590 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-3, Brown Fall 2014 Membro de USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 676
