Introdução
If your Apple Cinema Display M8149 control board isn't sending signals—leading to system crashes—use this guide to replace the faulty control board.
The control board is an essential part of the display as it is the component that acts as the nerve center that the CPU sends signals through. When those signals aren't being processed by the control board, that can cause the system to crash.
Before starting the steps be sure to power off the display and disconnect it from any external power source.
O que você precisa
Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
3 outras pessoas executaram este guia.
Um comentário
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
