Ir para o conteúdo principal
Access to RAM and CPU from why! W253EU
O que você precisa
  1. Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: passo 1, imagem 1 %32 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: passo 1, imagem 2 %32 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: passo 1, imagem 3 %32
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: passo 2, imagem 1 %32 Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: passo 2, imagem 2 %32
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Access to RAM and CPU from why! W253EU: passo 3, imagem 1 %32 Access to RAM and CPU from why! W253EU: passo 3, imagem 2 %32 Access to RAM and CPU from why! W253EU: passo 3, imagem 3 %32
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Access to RAM and CPU from why! W253EU: passo 4, imagem 1 %32
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
Conclusão
For reassembly, follow the instructions in reverse order.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Felice Suglia
Membro desde: 06/15/13
30.884 Reputação
Autoria de 263 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 257
