Ir para o conteúdo principal
Abu Garcia Black Max Spool Replacement
  1. Abu Garcia Black Max Spool Replacement, Spool: passo 1, imagem 1 %32 Abu Garcia Black Max Spool Replacement, Spool: passo 1, imagem 2 %32
    • Make sure you take off all the line on the reels spool.
  2. Abu Garcia Black Max Spool Replacement: passo 2, imagem 1 %32 Abu Garcia Black Max Spool Replacement: passo 2, imagem 2 %32
    • Take the black pin and apply pressure, pushing the pin to the left until it cannot go further.
    • On the right side of the reel, pull the side panel towards you until it pops up toward you.
  3. Abu Garcia Black Max Spool Replacement: passo 3, imagem 1 %32
    • Make sure you are still holding the pin to the left.
    • Slowly pull the side panel to the right until it comes off completely.
  4. Abu Garcia Black Max Spool Replacement: passo 4, imagem 1 %32
    • Grab the spool with your fingers, and gently pull out the spool from the reel.
    • Grab your replacement spool and have it ready for the next step.
  5. Abu Garcia Black Max Spool Replacement: passo 5, imagem 1 %32
    • Take your replacement spool and put the spool back inside the reel, the same way you pulled out the old spool.
  6. Abu Garcia Black Max Spool Replacement: passo 6, imagem 1 %32
    • Make sure that there are no spaces in the left and right sides of the spool once the new spool is in.
  7. Abu Garcia Black Max Spool Replacement: passo 7, imagem 1 %32 Abu Garcia Black Max Spool Replacement: passo 7, imagem 2 %32
    • Pull the pin to the left again.
    • Place the black side panel back onto the reel.
    • Once the black side panel is back on, apply downward pressure, pushing the black side panel back, until it clicks into place.
  8. Abu Garcia Black Max Spool Replacement: passo 8, imagem 1 %32
    • You have now done a complete spool replacement on the Abu Garcia Black Max baitcasting reel.
    • When you decide, you can now put the line back onto the spool.
Linha de Chegada
Daniel Minev
Membro desde: 01/10/24
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 56
Duração total: 234
