Ir para o conteúdo principal
Abask J05 Front Case Replacement
O que você precisa
  1. Abask J05 Front Case Replacement, Front Case: passo 1, imagem 1 %32 Abask J05 Front Case Replacement, Front Case: passo 1, imagem 2 %32
    • Gently press on the SD card with a fingernail until it clicks.
    • Release, then remove the card.
  2. Abask J05 Front Case Replacement: passo 2, imagem 1 %32
    • Remove the 5 mm screw from the side of the device next to the suction cup dock with a Phillips #00 screwdriver.
  3. Abask J05 Front Case Replacement: passo 3, imagem 1 %32 Abask J05 Front Case Replacement: passo 3, imagem 2 %32
    • Remove the two 8 mm screws from opposite sides of the screen with a Phillips #00 precision screwdriver.
  4. Abask J05 Front Case Replacement: passo 4, imagem 1 %32 Abask J05 Front Case Replacement: passo 4, imagem 2 %32
    • Gently lift the screen.
    • Push up on the interior camera portion of the device. It should pop out of the socket. Being careful to keep the wires attached, set it to the side.
  5. Abask J05 Front Case Replacement: passo 5, imagem 1 %32 Abask J05 Front Case Replacement: passo 5, imagem 2 %32
    • Reach into the device with a spudger to release the top two snap joints keeping the end cap attached one at a time until the front face lifts off.
    • Be careful not to touch the screen.
    • Repeat the process with the two remaining snap joints.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
99.240 Reputação
Autoria de 255 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.580 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 61
