Ir para o conteúdo principal
AYL SoundFit Speaker Replacement
O que você precisa
  1. AYL SoundFit Speaker Replacement, Motherboard: passo 1, imagem 1 %32
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Speaker Replacement: passo 2, imagem 1 %32
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Speaker Replacement: passo 3, imagem 1 %32
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Speaker Replacement: passo 4, imagem 1 %32 AYL SoundFit Speaker Replacement: passo 4, imagem 2 %32
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Speaker Replacement: passo 5, imagem 1 %32
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Speaker Replacement: passo 6, imagem 1 %32 AYL SoundFit Speaker Replacement: passo 6, imagem 2 %32 AYL SoundFit Speaker Replacement: passo 6, imagem 3 %32
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
  7. AYL SoundFit Speaker Replacement, Speaker: passo 7, imagem 1 %32
    • Using a soldering iron, heat up and remove the positive and negative wire contacts from the motherboard.
  8. AYL SoundFit Speaker Replacement: passo 8, imagem 1 %32
    • Remove four Phillips #1 screws to detach the speaker form the module.
    • Extract the speaker from the body of the AYL SoundFit.
Conclusão
Sajal Kherde
Membro desde: 02/16/16
107 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-3, Harley Spring 2016 Membro de IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 649
