Ir para o conteúdo principal
AYL SoundFit Battery Replacement
O que você precisa
  1. AYL SoundFit Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: passo 2, imagem 1 %32
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: passo 3, imagem 1 %32
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: passo 4, imagem 1 %32 AYL SoundFit Battery Replacement: passo 4, imagem 2 %32
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: passo 5, imagem 1 %32
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
Conclusão
Dustin Moore
Membro desde: 02/16/16
108 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-3, Harley Spring 2016 Membro de IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
Membros da 4
Autoria de 5 guias
4 comentários
Which battery is this, and what is the mAH?
jlongsa - Responder
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 2,785
