Ir para o conteúdo principal
AUX-208P1 Electric Kettle Temperature Controller Replacement
O que você precisa
  1. AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: passo 1, imagem 1 %32 AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: passo 1, imagem 2 %32
    • Clean all the dirt on the bottom of the electric kettle.
  2. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 2, imagem 1 %32 AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the three 19 mm screws at the bottom of the electric kettle.
    • Remove the base of the electric kettle.
    • Remove the LED indicator buckled on the base.
  3. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 3, imagem 1 %32 AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 3, imagem 2 %32
    • Use combination pliers to clamp the connection between the electric kettle line and the old temperature controller to create a gap, and pull it off.
    • Don't use too much force to avoid damage to the line!
  4. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 4, imagem 1 %32
    • Use combination pliers to remove the nuts holding down the old temperature controller.
  5. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 5, imagem 1 %32 AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 5, imagem 2 %32
    • Remove the broken temperature controller.
    • Clean the bottom of the kettle to remove any dust or debris buildup.
  6. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 6, imagem 1 %32
    • Align the socket on the bottom of the new temperature controller with the protrusion on the bottom of the electric kettle to assemble.
  7. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 7, imagem 1 %32
    • Use combination pliers to reinstall the nuts holding down the temperature controller.
  8. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 8, imagem 1 %32
    • Fasten the electric kettle circuit to the contact reed of the new temperature controller.
    • Gently pull the interface to ensure a firm installation.
  9. AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 9, imagem 1 %32 AUX-208P1 Electric Kettle Temperature Controller Replacement: passo 9, imagem 2 %32
    • Re-buckle the removed LED indicator back to the base.
    • Buckle the base back to the bottom of the electric kettle.
    • Use a Phillips #0 screwdriver to three 19 mm screws on the bottom of the kettle.
Conclusão
重新组装设备时,请依次相反的拆卸顺序。
Uma outra pessoa concluiu este guia.
SHAN HUANG
Membro desde: 01/13/21
193 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 68
Duração total: 1,149
