Ir para o conteúdo principal
ATT Trimline 210M Speaker Replacement
O que você precisa
  1. ATT Trimline 210M Speaker Replacement, ATT Trimline 210M Back Cover Disassembly: passo 1, imagem 1 %32
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Speaker Replacement: passo 2, imagem 1 %32
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Speaker Replacement: passo 3, imagem 1 %32
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Speaker Replacement: passo 4, imagem 1 %32
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Speaker Replacement, ATT Trimline 210M Motherboard Disassembly: passo 5, imagem 1 %32
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
  6. ATT Trimline 210M Speaker Replacement: passo 6, imagem 1 %32
    • Carefully move the motherboard up to remove it.
  7. ATT Trimline 210M Speaker Replacement, Speaker: passo 7, imagem 1 %32
    • Carefully detach the black and red wires
  8. ATT Trimline 210M Speaker Replacement: passo 8, imagem 1 %32
    • Use the iFixit iOpener to warm the adhesive from the front of the phone, in order to remove the speaker from the face plate safely.
  9. ATT Trimline 210M Speaker Replacement: passo 9, imagem 1 %32
    • Remove speaker
Conclusão
Uma outra pessoa concluiu este guia.
Corey
Membro desde: 02/10/16
343 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 4-2, Lacy Spring 2016 Membro de USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 334
