Introdução
You will need to remove the back cover to access the motherboard. The motherboard is held down by two screws, be careful however, since there are many wires attached to the motherboard from speakers and the microphone.
O que você precisa
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
