Ir para o conteúdo principal
ATT Trimline 210M Motherboard Disassembly
O que você precisa
  1. ATT Trimline 210M Motherboard Disassembly, ATT Trimline 210M Back Cover Disassembly: passo 1, imagem 1 %32
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Motherboard Disassembly: passo 2, imagem 1 %32
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Motherboard Disassembly: passo 3, imagem 1 %32
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Motherboard Disassembly: passo 4, imagem 1 %32
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Motherboard Disassembly, ATT Trimline 210M Motherboard Disassembly: passo 5, imagem 1 %32
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
  6. ATT Trimline 210M Motherboard Disassembly: passo 6, imagem 1 %32
    • Carefully move the motherboard up to remove it.
Conclusão
Juan Carrillo
Membro desde: 02/10/16
406 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 4-2, Lacy Spring 2016 Membro de USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 920
