Introdução
This guide will show you how to replace the keypad from the phone. You may need to replace it if the keypad doesn't work when attempting to dial.
O que você precisa
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
3 outras pessoas executaram este guia.
