Ir para o conteúdo principal
ATT Trek HD 9020A Screen Replacement
O que você precisa
  1. ATT Trek HD 9020A Screen Replacement, Back Cover: passo 1, imagem 1 %32
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD 9020A Screen Replacement: passo 2, imagem 1 %32
    • Pull the screen away from the back panel.
  3. ATT Trek HD 9020A Screen Replacement, Battery: passo 3, imagem 1 %32 ATT Trek HD 9020A Screen Replacement, Battery: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD 9020A Screen Replacement: passo 4, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
  5. ATT Trek HD 9020A Screen Replacement, Motherboard: passo 5, imagem 1 %32 ATT Trek HD 9020A Screen Replacement, Motherboard: passo 5, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
  6. ATT Trek HD 9020A Screen Replacement: passo 6, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 6, imagem 2 %32
    • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
  7. ATT Trek HD 9020A Screen Replacement: passo 7, imagem 1 %32
    • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
  8. ATT Trek HD 9020A Screen Replacement: passo 8, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 8, imagem 2 %32
    • Use angled tweezers to pry up the black tab.
    • Use the angled tweezers to pull out the gold connector.
  9. ATT Trek HD 9020A Screen Replacement: passo 9, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 9, imagem 2 %32
    • Use the angled tweezers to disconnect the gold connector.
  10. ATT Trek HD 9020A Screen Replacement: passo 10, imagem 1 %32
    • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
  11. ATT Trek HD 9020A Screen Replacement: passo 11, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 11, imagem 2 %32
    • Use the plastic opening tool to lift the motherboard out of place.
  12. ATT Trek HD 9020A Screen Replacement, Front Camera: passo 12, imagem 1 %32 ATT Trek HD 9020A Screen Replacement, Front Camera: passo 12, imagem 2 %32
    • Use the angled tweezers to lift the camera out.
  13. ATT Trek HD 9020A Screen Replacement, Screen: passo 13, imagem 1 %32 ATT Trek HD 9020A Screen Replacement, Screen: passo 13, imagem 2 %32 ATT Trek HD 9020A Screen Replacement, Screen: passo 13, imagem 3 %32
    • Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
    • Gently lift the black corner pieces out of the device.
  14. ATT Trek HD 9020A Screen Replacement: passo 14, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 14, imagem 2 %32
    • Use the angled tweezers to remove the black cables on each side of the device from their groove.
  15. ATT Trek HD 9020A Screen Replacement: passo 15, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 15, imagem 2 %32
    • Use the plastic opening tool to disconnect the black cable connectors from each side of the device.
  16. ATT Trek HD 9020A Screen Replacement: passo 16, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 16, imagem 2 %32
    • Remove the remaining ten 3 mm Phillips #00 screws.
  17. ATT Trek HD 9020A Screen Replacement: passo 17, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 17, imagem 2 %32
    • Use the plastic opening tool to disconnect the remaining three gold connectors at the bottom of the device.
  18. ATT Trek HD 9020A Screen Replacement: passo 18, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 18, imagem 2 %32
    • Use the plastic opening tool to pry up the grey plastic panel.
  19. ATT Trek HD 9020A Screen Replacement: passo 19, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 19, imagem 2 %32
    • Use the plastic opening tool to pry the screen out of the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 19
Duração total: 617
