Ir para o conteúdo principal
ATT EL52300 LCD Screen on Handset Replacement
O que você precisa
  1. ATT EL52300 LCD Screen on Handset Replacement, Battery: passo 1, imagem 1 %32 ATT EL52300 LCD Screen on Handset Replacement, Battery: passo 1, imagem 2 %32
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 LCD Screen on Handset Replacement: passo 2, imagem 1 %32
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 LCD Screen on Handset Replacement, Motherboard: passo 3, imagem 1 %32 ATT EL52300 LCD Screen on Handset Replacement, Motherboard: passo 3, imagem 2 %32
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 LCD Screen on Handset Replacement: passo 4, imagem 1 %32 ATT EL52300 LCD Screen on Handset Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 LCD Screen on Handset Replacement: passo 5, imagem 1 %32 ATT EL52300 LCD Screen on Handset Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: passo 6, imagem 1 %32 ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: passo 6, imagem 2 %32
    • The motherboard is connected to the ringer, which is clipped on to the back plate of your handset.
    • Pop off the indicated clip using a pointed tweezer.
    • With the motherboard disconnected from the back plate, turn it over so that the screen is facing you.
  7. ATT EL52300 LCD Screen on Handset Replacement: passo 7, imagem 1 %32 ATT EL52300 LCD Screen on Handset Replacement: passo 7, imagem 2 %32 ATT EL52300 LCD Screen on Handset Replacement: passo 7, imagem 3 %32
    • To get to the connection between the display and the motherboard, remove the casing for the display using a plastic opening tool.
    • The white casing has a hole cut into it. You are going to slide the display and the speaker through this hole.
  8. ATT EL52300 LCD Screen on Handset Replacement: passo 8, imagem 1 %32
    • The display has a line of soldered connections to the motherboard. These all need to be undone with a soldering tool, so the screen can be removed.
    • Please refer to the Como soldar e dessoldar contatos for soldering help.
Conclusão
Katty
Membro desde: 08/27/15
313 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-1, Sullivan Spring 2016 Membro de USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 425
