Ir para o conteúdo principal
ATT EL52300 Battery Replacement
  1. ATT EL52300 Battery Replacement, Battery: passo 1, imagem 1 %32 ATT EL52300 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 Battery Replacement: passo 2, imagem 1 %32
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
Conclusão
Katty
Membro desde: 08/27/15
313 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-1, Sullivan Spring 2016 Membro de USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 854
