Ir para o conteúdo principal
ATT CL4940 Internal Speaker Replacement
O que você precisa
  1. ATT CL4940 Internal Speaker Replacement, Internal Speaker: passo 1, imagem 1 %32 ATT CL4940 Internal Speaker Replacement, Internal Speaker: passo 1, imagem 2 %32
    • Unplug your device before beginning disassembly.
    • Remove phone line and power cord from the back cover of the device.
    • Remove phone cable from the side of the device.
  2. ATT CL4940 Internal Speaker Replacement: passo 2, imagem 1 %32
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Speaker Replacement: passo 3, imagem 1 %32 ATT CL4940 Internal Speaker Replacement: passo 3, imagem 2 %32 ATT CL4940 Internal Speaker Replacement: passo 3, imagem 3 %32
    • Starting from the bottom of the device, use a metal spudger, separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Speaker Replacement: passo 4, imagem 1 %32
    • Using wire cutters, sever both the red and black wires connected to the speaker.
    • Carefully remove the speaker from the assembly.
    • Be sure to remove the rubber gasket from the broken speaker. You will need this for reassembly.
Conclusão
Charles Moore
Membro desde: 02/16/16
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-2, Harley Spring 2016 Membro de IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 391
