Ir para o conteúdo principal
ATT CL4940 Internal Microphone Replacement
O que você precisa
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: passo 1, imagem 1 %32 ATT CL4940 Internal Microphone Replacement, Internal Microphone: passo 1, imagem 2 %32
    • Unplug your device before beginning disassembly.
    • Remove the phone line and the power cord from the back of the device.
    • Remove the phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: passo 2, imagem 1 %32
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: passo 3, imagem 1 %32 ATT CL4940 Internal Microphone Replacement: passo 3, imagem 2 %32 ATT CL4940 Internal Microphone Replacement: passo 3, imagem 3 %32
    • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: passo 4, imagem 1 %32
    • Using wire cutters, sever both the red and the black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling it apart.
Conclusão
Charles Moore
Membro desde: 02/16/16
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-2, Harley Spring 2016 Membro de IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
Membros da 4
Autoria de 8 guias
Um comentário
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 632
