Ir para o conteúdo principal
AT&T CL4940 Number Pad Replacement and Cleaning
O que você precisa
  1. AT&T CL4940 Number Pad Replacement and Cleaning, Number Pad: passo 1, imagem 1 %32 AT&T CL4940 Number Pad Replacement and Cleaning, Number Pad: passo 1, imagem 2 %32
    • Unplug your device before beginning disassembly.
    • Remove the phone line from the back cover of the device.
    • Remove the power cord from the side of the device.
    • Remove the phone cable from the side of the device.
  2. AT&T CL4940 Number Pad Replacement and Cleaning: passo 2, imagem 1 %32
    • Remove the five 4mm X 10mm screws from the back cover of the device using a Phillips #1 screwdriver.
  3. AT&T CL4940 Number Pad Replacement and Cleaning: passo 3, imagem 1 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 3, imagem 2 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 3, imagem 3 %32
    • Using a metal spudger, pry the white, plastic cover from the gray, plastic bottom. Start from below the keypad and work your way evenly around the device.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The internals of the device will be accessible once the white, plastic cover and grey, plastic bottom are separated.
  4. AT&T CL4940 Number Pad Replacement and Cleaning: passo 4, imagem 1 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 4, imagem 2 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 4, imagem 3 %32
    • Remove the five 5mm X 5mm screws located on the yellow side of the motherboard using a Phillips #1 screwdriver.
    • Set the motherboard out of the way.
  5. AT&T CL4940 Number Pad Replacement and Cleaning: passo 5, imagem 1 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 5, imagem 2 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 5, imagem 3 %32
    • Remove the two 5mm X 8mm large number pad screws using a Phillips #1 screwdriver.
    • Remove the 5mm X 6mm latch screw using the same screwdriver.
    • Remove the small, metal latch.
    • Remove the plastic plate previously secured by the screws and latch.
  6. AT&T CL4940 Number Pad Replacement and Cleaning: passo 6, imagem 1 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 6, imagem 2 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 6, imagem 3 %32
    • Remove the remaining six 5mm X 8mm large number pad screws using a Phillips #1 screwdriver.
    • Remove the two 3mm X 6mm small number pad screws using the same screwdriver.
    • Grab the edge of the number pad board and peel it away from the screw posts.
    • Using a clean towel or cloth, move the number pad board away from the keys that lie below.
    • Set the number pad board out of the way for further disassembly.
  7. AT&T CL4940 Number Pad Replacement and Cleaning: passo 7, imagem 1 %32 AT&T CL4940 Number Pad Replacement and Cleaning: passo 7, imagem 2 %32
    • Peel away the white, rubber mat and set it aside for cleaning.
    • Remove the main key pad and any remaining keys. Remember where each key is located for reassembly.
    • Clean the rubber mat with a damp paper towel to remove any dust or foreign substances.
    • Replace any broken or cracked keys.
Conclusão
3 outras pessoas executaram este guia.
Nigel Mathias
Membro desde: 02/16/16
215 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-2, Harley Spring 2016 Membro de IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 481
