Ir para o conteúdo principal
ASUS ZenWatch Motherboard Replacement
O que você precisa
  1. ASUS ZenWatch Motherboard Replacement, Watch Strap Removal: passo 1, imagem 1 %32 ASUS ZenWatch Motherboard Replacement, Watch Strap Removal: passo 1, imagem 2 %32
    • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
  2. ASUS ZenWatch Motherboard Replacement, Battery: passo 2, imagem 1 %32 ASUS ZenWatch Motherboard Replacement, Battery: passo 2, imagem 2 %32 ASUS ZenWatch Motherboard Replacement, Battery: passo 2, imagem 3 %32
    • Use the T5 Torx driver to remove the four screws on the case.
    • Use the magnetic pad to keep all your parts easily contained!
    • The case will pry easily off with just gentle hand pressure
  3. ASUS ZenWatch Motherboard Replacement: passo 3, imagem 1 %32 ASUS ZenWatch Motherboard Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, gently remove the fabric protecting the battery connection.
    • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
    • Use the heavy duty spudger to gently push the contact towards the top of the case.
  4. ASUS ZenWatch Motherboard Replacement: passo 4, imagem 1 %32 ASUS ZenWatch Motherboard Replacement: passo 4, imagem 2 %32 ASUS ZenWatch Motherboard Replacement: passo 4, imagem 3 %32
    • Gently pry the battery up with the plastic pry tools
  5. ASUS ZenWatch Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 ASUS ZenWatch Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 ASUS ZenWatch Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • With the metal tweezers gently remove the fabric covering the connection on bottom right
    • Using the heavy duty plastic spudger pry up on the connection ribbon.
    • There are two connection ports on the single ribbon. Do not use too much force as you may tear ribbon!
  6. ASUS ZenWatch Motherboard Replacement: passo 6, imagem 1 %32 ASUS ZenWatch Motherboard Replacement: passo 6, imagem 2 %32 ASUS ZenWatch Motherboard Replacement: passo 6, imagem 3 %32
    Heavy-Duty Spudger
    • The protective plate is now ready to be safely removed.
    • With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
    • There are tiny notches on plate making it simple to pull up on each side.
    • A small strip of adhesive is on back of plate as well.
    • Remove loosened plate and set aside.
  7. ASUS ZenWatch Motherboard Replacement: passo 7, imagem 1 %32 ASUS ZenWatch Motherboard Replacement: passo 7, imagem 2 %32 ASUS ZenWatch Motherboard Replacement: passo 7, imagem 3 %32
    • With the 000 Philips screwdriver remove the screw and plastic retainer clips
  8. ASUS ZenWatch Motherboard Replacement: passo 8, imagem 1 %32 ASUS ZenWatch Motherboard Replacement: passo 8, imagem 2 %32
    • With heavy duty spudger lift up on final connection ribbon located on left corner.
  9. ASUS ZenWatch Motherboard Replacement: passo 9, imagem 1 %32 ASUS ZenWatch Motherboard Replacement: passo 9, imagem 2 %32
    • With all the connections disconnected the motherboard can be gently pried up and out of the watch case.
Conclusão
3 outras pessoas executaram este guia.
Wayne McClure
Membro desde: 02/10/16
961 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Spring 2016 Membro de USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Membros
Autoria de 7 guias
Um comentário
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
Davy Jones - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,655
