Ir para o conteúdo principal
ASUS ZenWatch Charging Cradle Circuit board Replacement
O que você precisa
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: passo 1, imagem 1 %32 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: passo 1, imagem 2 %32 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: passo 1, imagem 3 %32
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: passo 2, imagem 1 %32 ASUS ZenWatch Charging Cradle Circuit board Replacement: passo 2, imagem 2 %32 ASUS ZenWatch Charging Cradle Circuit board Replacement: passo 2, imagem 3 %32
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
Conclusão
Wayne McClure
Membro desde: 02/10/16
961 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Spring 2016 Membro de USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Membros
Autoria de 7 guias
Um comentário
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 2,910
