Ir para o conteúdo principal
ASUS ZenPad S 8.0 Speakers Replacement
O que você precisa
  1. ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: passo 1, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: passo 1, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: passo 1, imagem 3 %32
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Speakers Replacement: passo 2, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 2, imagem 2 %32
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Speakers Replacement: passo 3, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 3, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 3, imagem 3 %32
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Speakers Replacement: passo 4, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 4, imagem 2 %32
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: passo 5, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: passo 5, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: passo 5, imagem 3 %32
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Speakers Replacement: passo 6, imagem 1 %32
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Speakers Replacement, Motherboard: passo 7, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement, Motherboard: passo 7, imagem 2 %32
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Speakers Replacement: passo 8, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 8, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 8, imagem 3 %32
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Speakers Replacement: passo 9, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 9, imagem 2 %32
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Speakers Replacement: passo 10, imagem 1 %32
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Speakers Replacement: passo 11, imagem 1 %32
    • Gently lift the motherboard from your device
  12. ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: passo 12, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: passo 12, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: passo 12, imagem 3 %32
    • To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
  13. ASUS ZenPad S 8.0 Speakers Replacement: passo 13, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 13, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 13, imagem 3 %32
    • Using the tweezers gently pull off the tape over the ribbon cable
  14. ASUS ZenPad S 8.0 Speakers Replacement: passo 14, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 14, imagem 2 %32
    • Using the tweezers gently pull the ribbon cable out from from the connector.
  15. ASUS ZenPad S 8.0 Speakers Replacement: passo 15, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 15, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 15, imagem 3 %32
    • Using the tweezers gently remove the connector from the yellow slot
  16. ASUS ZenPad S 8.0 Speakers Replacement: passo 16, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 16, imagem 2 %32
    • Cut the warranty tape connecting the daughter board to the metal plate under the battery
  17. ASUS ZenPad S 8.0 Speakers Replacement: passo 17, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 17, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 17, imagem 3 %32
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
    • Gently lift the daughter board from the device
  18. ASUS ZenPad S 8.0 Speakers Replacement, Speakers: passo 18, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement, Speakers: passo 18, imagem 2 %32
    • Gently lift up the speaker to remove it from the device
  19. ASUS ZenPad S 8.0 Speakers Replacement: passo 19, imagem 1 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 19, imagem 2 %32 ASUS ZenPad S 8.0 Speakers Replacement: passo 19, imagem 3 %32
    • Using the #00 Phillips head screwdriver, remove the 1.5mm screws
    • Gently lift up the second speaker to remove it from the device
Conclusão
John Astfanous
Membro desde: 10/04/16
987 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-2, Cagle Fall 2016 Membro de USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 975
