Ir para o conteúdo principal
ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement
O que você precisa
  1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: passo 1, imagem 2 %32
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 2, imagem 1 %32 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 3, imagem 1 %32 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 3, imagem 2 %32
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: passo 4, imagem 1 %32 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: passo 4, imagem 2 %32
    • Remove the six 3mm Phillips #00 screws holding the battery in place.
  5. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 5, imagem 1 %32 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 5, imagem 2 %32
    • Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
  6. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 6, imagem 1 %32
    • Carefully lift the battery up and out of the laptop.
  7. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: passo 7, imagem 3 %32
    • Remove four 3 mm Phillips screws (two on each side) holding the hard drive in the frame
  8. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 8, imagem 1 %32 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: passo 8, imagem 2 %32
    • Grip the side of the hard drive and slide it out of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Joshua Letizia
Membro desde: 10/30/19
193 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S4-G4, Saloman Fall 2019 Membro de UMass Dartmouth, Team S4-G4, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 578
