Ir para o conteúdo principal
ASUS ZENFONE 3 Zoom Front Camera Replacement
O que você precisa
  1. ASUS ZENFONE 3 Zoom Front Camera Replacement, Battery: passo 1, imagem 1 %32 ASUS ZENFONE 3 Zoom Front Camera Replacement, Battery: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 2, imagem 1 %32
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 3, imagem 1 %32 ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 3, imagem 2 %32
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 4, imagem 1 %32
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 5, imagem 1 %32
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 6, imagem 1 %32
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 7, imagem 1 %32
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Front Camera Replacement, Front Camera: passo 8, imagem 1 %32
    • Peel the copper adhesive off.
  9. ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 9, imagem 1 %32 ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 9, imagem 2 %32 ASUS ZENFONE 3 Zoom Front Camera Replacement: passo 9, imagem 3 %32
    • Unplug the front camera.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 708
