Ir para o conteúdo principal
ASUS X553SA-BHCLN10 Keyboard Replacement
O que você precisa
  1. ASUS X553SA-BHCLN10 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 ASUS X553SA-BHCLN10 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Power off laptop.
    • Flip over the laptop so the model stickers are pointing towards the ceiling.
  2. ASUS X553SA-BHCLN10 Keyboard Replacement: passo 2, imagem 1 %32 ASUS X553SA-BHCLN10 Keyboard Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the six 10.5mm screws (shown in red).
    • Use a Phillips #0 screwdriver to remove the four 5.5mm screws (shown in orange).
  3. ASUS X553SA-BHCLN10 Keyboard Replacement: passo 3, imagem 1 %32 ASUS X553SA-BHCLN10 Keyboard Replacement: passo 3, imagem 2 %32
    • Turn over the laptop with the keyboard facing upwards.
    • Insert a plastic opening tool under the edge of the laptop.
  4. ASUS X553SA-BHCLN10 Keyboard Replacement: passo 4, imagem 1 %32 ASUS X553SA-BHCLN10 Keyboard Replacement: passo 4, imagem 2 %32 ASUS X553SA-BHCLN10 Keyboard Replacement: passo 4, imagem 3 %32
    • After prying open all sides of the laptop, carefully remove the keyboard from the laptop.
    • Carefully remove the two cables connecting the keyboard to the laptop by popping up the white clips and sliding the connector out.
Conclusão
Uma outra pessoa concluiu este guia.
Spencer Lee
Membro desde: 11/01/18
268 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G4, Harley Fall 2018 Membro de IUPUI, Team S2-G4, Harley Fall 2018
IUPUI-HARLEY-F18S2G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 15
Duração total: 541
